Old 09-02-2007, 11:32 PM   #1
Uncrated
Banned
Default Nova weight reduction program
During the upcoming off-season, I plan to remove some front-end weight from my 1970 Nova. One area of reduction will be the factory control arms, another will be brakes, and a third will be a fiberglass front end.
My questions are who makes a nice, lightweight control arm designed for a coil over shock and spring. In addition, should I be looking at the QA-1 shock that uses the tapered spring? On the other hand, should I mount a conventional coil over system by building a custom upper mount?
I would also like to hear you experience about brake kits.
My small block Nova runs mid 10?s at 3200 pounds and after the weight reduction program; I expect it to weight about 2800 with driver. This work is in preparation for some Super Street races during the 08 season.
Thanks for your feedback
Larry Woodfin
Uncrated is offline   Reply With Quote
