Old 12-14-2017, 01:05 PM   #1
jmoneyfoot
Liked 9 Times in 5 Posts
Default Switch to 2bbl
I currently have a dish piston 305 how much slower can I expect it to run with a 2 Barrel. Thanks for the input.
jmoneyfoot is offline   Reply With Quote
Old 12-14-2017, 06:01 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Switch to 2bbl
My 69 Chevelle wagon ( 3865 lbs) slowed .5 or so from a Q-jet to a 2GC.
Mike A114
Old 12-14-2017, 06:17 PM   #3
Liked 5,124 Times in 1,953 Posts
Mike A114
Mike, Much bigger 2 bbl. on a bigger engine...Probably can't read too much into this.
Mr Money, Not enough info here. Depends on who built the 2 bbl, the 4 bbl, and the engine, itself.
Maybe the wizard on the hill in Pa. will take a WAG at it?
Old 12-14-2017, 06:47 PM   #4
jmoneyfoot
Motor ran. 80 under with 4bbl. Having Dean Oliver build my 2gc. Not sure how good the intake is. It's going in a 77 Buick skylark that will fall into R/SA.
Old 12-14-2017, 06:50 PM   #5
Mike Jones
Thanks Mark
Al Peters told me the difference between the small 2GC and the big one, is also about .5
Mike A114
Old 12-14-2017, 08:27 PM   #6
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
I run the same combo in 1978 nova: reasonable motor, deano carb, cam was ground for a four barrel. Ran mostly mid 13.8's in fair air, 13.7's in good air, mph mid 93 at 3450 weight in R - when HP was 180 in 2016 season. Running stock aluminum intake, not tried the cast intake as yet, for 1978 both are legal. Don't know how this will compare to your 4 bbl numbers.
Mike Moller
NHRA 203 Q-R-T/SA
Old 12-15-2017, 02:25 AM   #7
Tom Moock
Liked 10 Times in 6 Posts
Jmoneyfoot, 305 dish piston motor, intake valves are different size, on 2 barrel & Q-jet. on 350 Q-jet & 2 barrel motor have same size valves, easer to switch 2 barrel to Q-jet.plus 2 barrel on 350 are bigger size than 305.
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 12-15-2017, 08:27 AM   #8
Liked 10,720 Times in 2,232 Posts
Mr. Billy uses the SWAG method. With Billy it's science!
Old 12-15-2017, 09:05 AM   #9
Billy Nees
Liked 7,745 Times in 1,740 Posts
Really good intake, really good head (don't worry about the small intake valves), bigger cam than 4V and carb flows about 325 CFM (before Deano).
There's a very good one here in Div.1 in a Malibu wagon that runs R and T and when it pops up it's usually a second under car. Much better combo than my 307.
Billy Nees 1188 STK, SS
Old 12-15-2017, 12:33 PM   #10
Tom Moock
Billy, same cam 78 Malibu 2 barrel & 79 Malibu Q-jet, I thought about useing 2 barrel on my Malibu, but you had to change heads.
Tom Moock 5704 STK
