Old 09-01-2007, 09:33 PM   #1
vic guilmino
Liked 56 Times in 21 Posts
Angry need help with innolvate dl-32
can't figure this thing out it is a innolvate dl-32 and i can't get this thing to work
help
Vic Guilmino 1129 STK
Old 09-02-2007, 06:50 PM   #2
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: need help with innolvate dl-32
Are you able to monitor the AFR while the car is running, but can't figure out how to record and play back?
If so, it doesn't have play back capability. It took me a while to figure out that you can record for only a very brief period of time and download a stiil graph onto your laptop, but the graph axis will be the time from when you push the red button, not RPM. You can usually tell when the car launched, because the graph jumps sharply, or at least it does with my Q-Jets.
Or you can buy another module from Innovate that will record and playback, plus it has an rpm pickup. I think it costs another $350. Or link it to a data acquisition system for a few grand more.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 09-02-2007, 09:20 PM   #3
bseibenick3137
Liked 5 Times in 2 Posts
Vic, if you still need help send me an email to brian@toledo-dyno.com with your contact info. I am an Innovate dealer and I run a DL-32 in my stocker.
Brian Seibenick
R/SA 3137/3157
bseibenick3137 is offline   Reply With Quote
Old 09-03-2007, 01:28 AM   #4
vic guilmino
tony
are you going to etown???
i can't get anything to work oil or fuel pressure, wter temp drive line or feul ratio
tack reads 800 low???
can't figure out anything
do not know where to hook the wires from the sensors
vic guilmino
Old 09-03-2007, 09:39 AM   #5
Tony Curcio
I'm not racing, but I have an appointment in Asbury Park on Saturday at 11:00 AM, which is only 20 minutes from the track. I was planning to stop at the track on the way home to watch first round elims.
I'll bring my laptop and look for you. I think I can get the AFR readings for you. As for the rest, it may turn out to be a case of the blind leading the blind, but I'm willing to try if you are.
E-mail me at acurcio910@aol.com and I'll send you my cell number.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
