Old 12-04-2017, 04:07 PM   #1
Nmbr1GMfan
Liked 1,954 Times in 491 Posts
Default Spindle question.
I have light brakes on a heavy spindle (76 nova) is there a drum spindle I can use with these brakes that will shed some weight?
Todd Greene
Old 12-04-2017, 04:19 PM   #2
PJ305
Liked 5 Times in 4 Posts
Default Re: Spindle question.
NHRA only allowed aftermarket brakes for safety purposes! Your Nova only came with factory front disc brakes and you are only allowed to use the stock spindles to be legal!
PJ305 is offline   Reply With Quote
Old 12-04-2017, 05:04 PM   #3
Nmbr1GMfan
Thank you!
Todd Greene
Old 12-04-2017, 09:24 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The NHRA allowed part is a bit deceiving. This is what the 2017 book says for Stock:
BRAKES
Must be equipped with stock production four-wheel hydraulic
brake system, or aftermarket disc brakes meeting the following
criteria:
1. Minimum effective piston area per wheel: 3 1/2 square inches.
2. Minimum disc (rotor) diameter 10 1/4 inches x 5/16-inch thick.
3. Must install dual master cylinder with any modified brake
system, splitting front and rear into separate systems.
4. Dual calipers on rear wheels permitted, maximum one
hydraulic brake line to dual rear brake system (no wires).
5. Rear wheel line-loc prohibited; front wheel line-loc permitted.
Parking brake optional.
6. Carbon-fiber brake rotors prohibited.
See General Regulations 3:1.
As far as spindles go. Stock.
Dale Shearon
68 Mustang 6394
Old 12-04-2017, 09:41 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Couldn't you buy a brake package that included the spindles ? Those spindles might not have that extra metal on them . I know of some aftermarket brakes need the spindles sent in for them to be modified .
Old 12-04-2017, 11:06 PM   #6
Nmbr1GMfan
Hmmm.
Todd Greene
Old 12-05-2017, 08:27 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
SUSPENSION, Front
"Must retain complete stock front suspension system as produced by manufacturer for body used, aftermarket tie rods with Heim joints permitted. Lower control arm may be machined for larger shock diameter and mount. Lift kits/travel limiters prohibited. Sway bar optional."
This seems to rule out replacing the spindles.
Old 12-05-2017, 10:13 AM   #8
Nmbr1GMfan
Yup.
Todd Greene
Old 12-05-2017, 10:35 AM   #9
Jeff Stout
Liked 704 Times in 281 Posts
Sounds like I'm putting my spindles back on Olds wagon and not using G body spindles
Old 12-05-2017, 11:07 AM   #10
Nmbr1GMfan
Yeah I'm leaving them alone.
Todd Greene
