Old 12-02-2017, 11:02 PM   #1
Nmbr1GMfan
Default Front coil spring options?
Since you guys helped me out so much on my shock questions, I'm starting to wonder about springs. This car ('76 Nova) has cut stock front coils and I was just going to put them back in. Should I "spring" for some good ones? Will it be worth the investment? If so, who do I call? Thanks in advance!
Todd Greene
Old 12-03-2017, 10:58 AM   #2
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: Front coil spring options?
Todd, if it was mine, I'd go back together with what was in there, at least to start with. The front shock change may be all you need. Stockers can be fussy with the front springs. But not always. There's a balance between ride height, stored energy (to get the car up) and control when the front end comes down.
Starting with what worked pretty well isn't a totally bad approach. -Al
"That'll never work....."
Old 12-03-2017, 11:09 PM   #3
Nmbr1GMfan
Thanks Alan!
Todd Greene
Old 08-25-2018, 03:17 PM   #4
David Lee
Liked 346 Times in 126 Posts
Originally Posted by Nmbr1GMfan View Post
Thanks Alan!
Do you know how many coils were cut from the springs?
Thanks
Dave
Old 08-25-2018, 03:42 PM   #5
Painter
Liked 162 Times in 45 Posts
I would go with the morose small block springs cut to eleven coils. I don't remember how much you cut to get them at eleven. It may sit a little high at first but will settle. Make certain you get the springs in the notches.
Painter is offline   Reply With Quote
Old 08-25-2018, 04:45 PM   #6
David Lee
i have a set of the "trick springs". And thanks for informing me of the cut amount. But I would like to find out how much Todd cut, so I can test to see what spring will give me the best result.
Old 08-25-2018, 06:09 PM   #7
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I would go with a Santhuff spring right off the bat.You may have to give them your front end weight.after that there's no cutting involved.They cost a bit more but don't sag after awhile like a moroso. gsa612
Old 08-25-2018, 09:35 PM   #8
J&S Racing
Liked 327 Times in 87 Posts
I believe santhuff sells Landrum coils....
I went with the 180# springs. I haven't had my car on the ground with the front sheet metal but I bet I end up cutting a coil or 2.
After all the research I did on front springs, the consensus was they store the most energy but running down the track you have that nose high stocker...
Old 08-26-2018, 08:53 PM   #9
MR DERBY CITY
Liked 8,206 Times in 1,536 Posts
The reason you buy Landrum springs is to NOT cut a coil or two, They are an excellent spring and are head and shoulders better than the Moroso. If ride height is an issue you don’t have the correct spring BUT, put your torch away.....LOL.....
Old 08-26-2018, 09:51 PM   #10
james schaechter
If you race a stick car with stock front coil springs or old school chopped morosos you are missing out! As far as cutting, the ones we got could trimmed with a cutoff wheel, but I would not do that unless you would give them some time to settle. Ours did drop a bit. They made a huge difference for us when track conditions were not so good. The springs don’t last forever either.
James Schaechter 3163 STK
