Old 11-30-2017, 10:28 PM   #1
BTR69
BTR69's Avatar
Liked 74 Times in 24 Posts
Default Cracked Block
Cracked 454 block from water jacket running toward lifter valley. Repairable? If so, would it be worth the expense? It's a 98 from a 3500 HD dually. If it matters, it's an L29 option. I'm under the impression the heads flow very good and would be good to keep. Hopefully the picture shows a good image of the damage.
Name:	cracked engine block 4.png
William Kilduff
1970 Barracuda (still under construction, indefinitely)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
