Old 11-27-2017, 09:45 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Question opinions on sb Chev cam
3000 lb car /350 flat top pistons for brackets and some S/SS . Solid roller 630 lift, 276 / 284 @ 50 ,107 CL , is this too much cam or is it a parts breaker ?
Mike Savelle is offline   Reply With Quote
Old 11-27-2017, 10:25 AM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Default Re: opinions on sb Chev cam
Good choice but could use more lift. Don't know how violent the lobes are.
Old 11-27-2017, 05:05 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
If its an automatic it would probably like a 105 Lobe center. What rocker arms are you using?
Mike Pearson 2485 SS
Old 11-27-2017, 05:42 PM   #4
Mike Savelle
Smile Re: opinions on sb Chev cam
yes it's auto. , not sure on the rockers , its a used cam , I'm trying to. convert my crate motor to a mild GT/SS , got some heads and a q jet. Only ever had stocker cams so I'm not up on what I should use , all I have to do is cut the index , not looking to set the record . thanks
Old 11-27-2017, 07:08 PM   #5
Mike Pearson
That cam will get you to the index. If you have some decent heads and carb
