Old 11-21-2017, 02:37 PM   #1
Craig Dawson
Liked 78 Times in 19 Posts
Default Chrysler 8.75 for Aspen/Volare
Need some advice for installing an 8.75 in a 79 Aspen. Would a B body rear end be the closest fit for width? Currently has an 8.25. Thanks, Craig.
Craig Dawson is offline   Reply With Quote
Old 11-21-2017, 02:41 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,124 Times in 962 Posts
Default Re: Chrysler 8.75 for Aspen/Volare
What kind of power and which class are you setting up for? Early B Body is close but you still have to offset springs and/or move the pads. If you’re going with a lot of power and/or trans brake go directly to a Dana.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-21-2017, 02:57 PM   #3
65signet
Liked 44 Times in 21 Posts
68 to 70 B body is the one you need.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 11-21-2017, 04:45 PM   #4
Paul Precht
Paul Precht's Avatar
Liked 307 Times in 116 Posts
I put an 8 3/4 from a 71 Charger in a 76 Volare, the locating pins were less than an inch off, I elongated the shock plates with my die grinder, it was almost a bolt in.
Old 11-21-2017, 05:15 PM   #5
ToddKuhn
Used 69 b B body on my sons 76 volare and it fit without much trouble at all . And I am not a mopar man at all YET. lol Now if I could just find a grill that's what I am having problems with.
ToddKuhn is offline   Reply With Quote
Old 11-21-2017, 06:25 PM   #6
Dave Gantz
Liked 251 Times in 125 Posts
https://www.bing.com/search?q=mopar%...logo=CT3210127
Old 11-21-2017, 08:17 PM   #7
Coleydog
Liked 53 Times in 38 Posts
Find a 66-67 rear, shorter that the 68-70. Doesn't it have to be the same back plate to back plate measurement as the 8-1/4 or whatever was in it?Gotta put axles-spool in anyway, cut it to the right length.
Old 11-21-2017, 08:54 PM   #8
Dave Gantz
He has to tell us if the car is a Stock Elim car or?
Old 11-21-2017, 11:49 PM   #9
Craig Dawson
It's a 318 4bbl. N/SA. also toying with the idea of building the 8.25 rear. Just not sure if it will hold up over time. My gut feeling is to go with the 8.75, just a little more hassle to locate the best choice housing and modify it to fit.
Old 11-22-2017, 12:49 AM   #10
Paul Precht
Only if you're using the same wheels and tires, which you're not.
