Old 11-20-2017, 09:33 AM   #1
R5ROB
R5ROB's Avatar
Default Modified super stock tech help
Decided to run modified super stock
Can I run dry sump system and is there a restriction on fuel ?
Thanks Bob
R5ROB is offline   Reply With Quote
Old 11-20-2017, 09:38 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Default Re: Modified super stock tech help
Do you have a rule book?
Old 11-20-2017, 10:19 AM   #3
R5ROB
R5ROB's Avatar
Just ordered one this morning
Old 11-20-2017, 10:23 AM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
Unless something has changed the MX classes are the only ones you can run a dry sump in. Fuels, there is an accepted list on NHRA's site I believe.
Joe Buchanan SS/BX 3117
Old 11-20-2017, 10:24 AM   #5
Hacksaw
Liked 306 Times in 172 Posts
Dwight is right. Get a rule book. Dry sump permitted in SS/MX only. Fuel options and restrictions. Plan, plan, and plan some more. Good luck.
Old 11-20-2017, 10:27 AM   #6
Dwight Southerland
Accepted fuel is found here:
http://www.classracerinfo.com/AFuelList.aspx
and here:
http://promod.nhra.com/userfiles/fil...edProducts.pdf
Old 11-20-2017, 06:01 PM   #7
SSDiv6
Liked 1,538 Times in 575 Posts
Either an internal wet-sump oil pump or an external, single-stage oil pump is all that is allowed.
Old 11-21-2017, 01:48 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Thanks Bob
Modified Stock (SS/CS) or Modified (SS/CM)? Lotta stuff down there past GT/.
All those classes follow SS rules with exceptions listed separately in the book.
Dry sump is allowed in SS/ES, SS/FS and SS/GS which are 4 cylinder classes.
Read the rules line by line and ask questions. Best suggestion is to find a racer running your engine build in your chosen category. That will take a lot of the guesswork out of the process for you.
Dale Shearon
68 Mustang 6394
Old 11-21-2017, 04:45 PM   #9
buzzinhalfdozen
Unless it has changed just recently ES, FS,and GS are only allowed single stage external pumps...since we no longer get a rule book as part of the membership I'd have to look online.
Old 11-22-2017, 07:01 PM   #10
FireSale
FireSale's Avatar
This is from my copy of the 2017 book. It's the Modified Stock section. Modified doesn't mention the dry sump part.
"OIL PUMP
External single-stage oil pump permitted.
OIL SYSTEM
Dry-sump system allowed in ES, FS, and GS."
Dale Shearon
68 Mustang 6394
