Old 11-18-2017, 01:30 PM   #1
rich freitag
Default 70 Javelin with mopar 8 3/4
I am building a 70 Javelin forNHRA
stocker ,I installed a mopar B body 8 3/4 rear and the center section it is offset.Will this cause any problems with the stock drivetrain.I am running a AMC 360 with a 727 trans.Should it be 0 offset ?
Rich Freitag 1440 SS
rich freitag is offline   Reply With Quote
Old 11-18-2017, 02:21 PM   #2
Rod Greene
Liked 242 Times in 81 Posts
Default Re: 70 Javelin with mopar 8 3/4
Mopar offsets the drive train 1 inch to the right (passenger side). If AMC has the drive train centered that is where the pinion should be. You should measure and set the pinion so there is no side to side angle. The only angle you should have is down. If you haven't spent much on the 8 3/4 I would put a Dana 60 in the car. It is stronger and faster.
Good luck.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 11-18-2017, 03:03 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 70 Javelin with mopar 8 3/4
If building a class car and it's available, a 904 is faster than a 727. Chrysler did some testing back in the '70's and it was about .15, all else being equal, plus you'll have the option of a less expensive 2.74 low gear set from a later trans.
General question - since the pinion is offset in Mopars with similar drivetrains & suspension, would matter if it was in an AMC or Mopar body?
LOCOMOTION Racing
Old 11-19-2017, 10:29 AM   #4
Coleydog
Liked 53 Times in 38 Posts
Just to clearly, an 8-3/4 is not offset (center section) it's the pinion. Whereas the Dana is offset (center section) because the pinion is not as offset as the 8-3/4. I would like to see how many tenths of a horse power you would lose by being "not centered" when the up and down movement (car separation) is astronomical. Now if you're running a four link, go for it.
Mike
Old 11-20-2017, 09:36 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
I would use a Dana 60 rather than the 8 3/4.
Old 12-01-2017, 03:22 AM   #6
amxron
An 8.75 isn't much stronger than an AMC-20 with 1 piece axles.
I ran for years with Henrys Axles, an AMC left hand thread TwinGrip & 4.44's
and the tubes welded in. (390/4sp D/Stock).
Ron.
amxron is offline   Reply With Quote
