Liked 648 Times in 193 Posts
2007 Ford F350 4x4 FX4 long wheel base Lariat Package 4 door crew cab. Truck is rust free, tutone dark blue with gold bottom, Leather, Kenwood Stereo & CD Player, truck has 155,xxx miles. Comp T/A Off Road tires. 4.30 gears both diffs. All Lariat options including heated front seats. LineX spray in bed liner.
6.0 Diesel, ARP head bolts, aftermarket turbo, AEM cold air intake, 5" mandrel bent straight exhaust with 6" stainless tip. Tubular Griller with Chrome Grille Guard front end. Truck is in excellent shape gets 24 to 26 hwy, 18 to 19 in town. Has BW Gooseneck & is setup for 5th wheel just need the insert. Truck will pull anything you want to put behind it. Oil & Filters (Motorcraft filters only) changed every 5,000 miles, 15-40 Rotella used since new. No oil leaks, no smoke, no loss antifreeze. Coolant flushed every 15,000 miles, diff oils changed every 40,000 miles. Tranny fluid changed every 40,000 miles. Had to replace the FICM and a few injectors. Jimmy Jammer Plates installed at all 4 doors (anti-theft). Pictures are available upon request. Carfax shows original owners hit a deer damage was (minor)grille and front bumper only and was replaced. Truck shows excellent and very clean. Also comes with SGT Livewire tuner that has never been put on. $21,000 832-727-0326 Last edited by nickh; 11-15-2017 at 12:56 PM. |
Sold!
