Old 10-30-2017, 02:25 AM   #1
craiger
Default HELP,HELP pontiac gurus
Want to run a .040 over 400 pontiac72-7500 rpm.
stock 68 400 crank, 63 421 sd reconditioned rods, .040 10:5 trw pistons 68 pontiac 400 heads comp. valve job with 1.65 harlan sharp rockers offenhauser low rise 2 4 bbl. manifold with 2 625 afbs, .600 lift 270 duration flat tappet cam, jackson gear drive, ati balancer, freshened mallory super mag circa 1970, butler valley support. 93 octane pump gas???
will my junk live to 7500 rpm,, have had bbcs,sbcs, 426 hemis, but never a poncho and have not a clue
craig esposito
sagarth.espo@gmail.com
craiger is offline   Reply With Quote
Old 10-30-2017, 07:32 AM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: HELP,HELP pontiac gurus
craig esposito
All of the Pontiac people/racers I know, talk low rpm torque, not 7500.
Looking forward to other replies.
Good luck with your project.
Mike A114
Old 10-30-2017, 08:10 AM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
"will my junk live to 7500 rpm"
NO !
Rich Biebel
S/C 1479
Stock 147R
Old 10-30-2017, 12:08 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Heavy pistons , need a better connecting rod . You must have pretty decent heads if you are winging that engine to 7500 . Its possible !
Old 10-30-2017, 04:18 PM   #5
1legjerry
Liked 72 Times in 15 Posts
Yes, you can build a Pontiac 400 that will do 7500. But the parts you listed will likely not get you there.
I'm thinking a lighter piston, Lighter 326 or 350 crank, Way better intake. A Professional port and valve job. and a roller cam would be nice.
Spinning 7500 and making power at 7500 are 2 different things.
1legjerry is offline   Reply With Quote
Old 10-30-2017, 07:11 PM   #6
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
What I remember of Pontiac's from when I had one was CAST connecting rods, not Forged. But the SD rods, I don't know. Looks like Scat and Eagle make forged rods for it.
Dave Noll, EF/S ,?/SA 6526
Old 10-30-2017, 09:06 PM   #7
ss3011
ss3011's Avatar
The SD rods are forged , but the early ones still had 3/8" bolts , the 73/74 SD rods had 7/16" bolts , most of the aftermarket rods have 7/16" cap screws .
Old 10-30-2017, 11:12 PM   #8
Bruce Fulper
Liked 54 Times in 33 Posts
What are you guys doing in my garage. :-)
Do NOT even attempt this. It's taken me a long time to find out what works, what lives, and how high of rpm I can go SAFELY.
You tell me the car, the race weight and the ET you'd like. Get that 7500 rpm stuff outa your head. That's not a smart way to approach a project.
And spend $300 bucks on some chinese rods which are way stronger than any factory rod made. I hate it too. (Off shore stuff) But 98% of my customers act like they're dead axx broke, but want the double throw down massive hp. So they get the rod that's very good, and cheap.
Bruce Fulper is offline   Reply With Quote
Old 10-31-2017, 05:58 AM   #9
craiger
Angry Re: HELP,HELP pontiac gurus
UGGGH!!! ok so I can not wring this motor where I want to. Bought a set of Molnar rods so maybe it will live @6200-6400 rpm. It is a street car with a pro-shift nash 5 speed but I like shifting at 7000+ rpm ,looks like I will have to learn to shift at 6200. non-tubbed car will be fun trying to hook up this
torque monster using 1972 technology. Extended lakewood slappers and a decent adj. shock, 9 or 10 inch tires. Doing a street-strip car like we had in 1972. Frame connectors but no cage.
Old 10-31-2017, 09:06 AM   #10
craiger
anybody that wants to b.s. and tell me i'm a moron give me a call
especially bruce fulper
330 831 4480 anytime
