Old 10-29-2017, 11:13 PM   #1
john billups
Default Qjet idle rich.
GM 1980 305 w/ stocker cam, 2-3 inch vac.
I cant get a good idle, it loads up and it falling over about 90 ft. out then pickup a sec. later.
The carb was built by a local SS racer a few years ago. It has the pri. rods removed.
I have to have the throttle open a lot of turns to keep it running.
The fuel is being pulled from the mains and the idle screws have little affect.
I have tried other Q jet carbs, even a new Jet stage 3.
I guess the question is, how do I get this to run right.
john billups is offline   Reply With Quote
