Old 10-18-2017, 10:26 AM   #1
Rick.H
Default Which Strange master cylinder in a 4-gen F-body
Have a -97 Formula with strange 4 piston calipers front + rear.
Strange recommend the master cylinder with 1.125 diameter bore.
Anybody with experience or is 1.032 master cylinder better choice.
I might get very strong right leg.
Rick.H is offline   Reply With Quote
Old 10-18-2017, 12:35 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Which Strange master cylinder in a 4-gen F-body
A 1.062 diameter Wilwood will work the best for the Fbody with 4 wheel discs and a 6 to 1 pedal ratio .
The 1.032 will work, but you will have a fairly soft ,deep pedal.
The 1.125 will require a strong leg with a 6 to 1 pedal to get much more than 900 # pressure . .....It will work with a 7 to 1 ratio , but the pushrod geometry is not so good.
Regardless of which you choose be sure to use some sort of retainer for the push rod beside the rubber o ring.
Old 10-22-2017, 02:43 PM   #3
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Im working with aerospace and the tech has been great help. Most polite informative guys. Im at 6-1 and have 800 psi. Changing ratio to 7-1 as recommended.
Hoping for close to 1000 psi.
chris ok is offline   Reply With Quote
Old 10-27-2017, 07:49 PM   #4
GTX JOHN
Liked 2,490 Times in 700 Posts
The Mopar master cylinders we have encountered have different proportions
from front to back depending on part # and bore size plus application
(IE 61/39 or 69/31).
Is that not important?
John Irving
741 Stock
741 Super Stock
