Old 08-28-2007, 10:55 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question What makes a towing package a towing package ???
I have found a 2006 2500 series Suburban I really like and the price is right, but there are no towing package options on this vehicle......besides a hitch, special rear end gear ratio and transmission cooler, what else would it take to make this a reliable vehicle a tow vehicle???? What would you guys want to add ???? Any opinions out there ????
Rusty Davenport is offline   Reply With Quote
Old 08-28-2007, 04:44 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: What makes a towing package a towing package ???
Heavy duty tires---New brakes---HD shocks and the largest trans cooler you can find that will fit ---also might bypass the radiator and just cool the trans by way of the trans cooler---Comp 387
Old 08-28-2007, 05:56 PM   #3
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Aditionally the factory tow packages include an engine oil cooler. The radiator may be a larger core for the tow package and the wiring harness for the trailer may be tucked uo around the frame. That's about all you get with a factory tow package beside the axle ratio and posi-traction.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
