Old 09-23-2017, 04:33 PM   #1
voltdr
Liked 100 Times in 51 Posts
Default Onan qg 7000
I just bought a used Haulmark trailer that has a RV QG 7000 generator. It will only run for 15-20 minutes. After it cools down it will do the same thing. It flashes a 33 code. I checked and found that the fuel pump is NOT running and that even when cranking and/or priming, there is no power getting to the pump. Am I correct in thinking that the power for the pump comes through the control board?
Thanks for any info.
Dan
voltdr is offline   Reply With Quote
Old 09-25-2017, 10:38 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Onan qg 7000
Yes you are correct and it's a common problem.
PC board/control output for the fuel pump and carb solenoid are the same circuit....
After the board gets warm that circuit fails.
Replace the control .....probably an Onan #300-5047
Rich Biebel
S/C 1479
Stock 147R
Old 09-27-2017, 12:47 PM   #3
voltdr
Thanks Rich. That was the problem. All is working now.
Dan
