Liked 33 Times in 16 Posts
I'm adding a winch to a new enclosed trailer soon and was wondering what type of battery would give the best performance and longest life? Conventional cranking...deep cycle? This one will be wired to charge from the tow vehicle's alternator when running down the road and while in use...of course a battery tender for when it sits idle. The winch is rated at 4500 pounds if that makes any difference. Thanks for any input in advance.
Rich Taylor I/SA - 321 |
#2 | |
Liked 801 Times in 338 Posts
My trailer came with two batteries although I think most just come with one. They mount in battery boxes on the tongue, however I notice in a lot of new trailers they mount under the counter in a battery box that is vented to the outside. Bill |
I had a winch reinforcement plate welded under the floor off to the side on the new trailer. Will be adding the battery/box right beside it against the side wall. I figured a center mounted winch would be a constant nuisance with a cable stretched out right in the middle of where the pit bike/golf cart will be tied down.
Liked 2 Times in 2 Posts
I have a group 27 deep cycle battery mounted under the bench. It is wired to charge from the tow vehicle going down the road and I use a battery tender when it sits in the yard.
I did this when I purchased the trailer in 2010 and I have had no issues.
1969 camaro, pump gas 540"bbc, jerico 1967 camaro, pump gas efi 620", coan t-400 |
