Old 08-24-2007, 08:42 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Spark plugs
History on this car is a little vague, I bought it a month ago and everything is a learning curve. Yes this is a bracket car.
1974 Duster 383/727/4:56 the 383 is a 10 to 1 flat top motor, solid cam, 10" convertor
It had a Holley 750 DP, but when I got it that had been replaced with a 650 Holley DP.
I'm shopping for another Holley 750 DP carb for it.
Ok the plugs are Champion J12YC in it now.
Looking for recomemdations, opinions, suggestions on a good plug to try.
I made the mistake of going to my local Pepboys (somewhat better than Autozone) and
asking for a set of these plugs, of course the answer was NO GOT, how about a set of
AC Delco plugs computer says a straight match up.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 08-24-2007, 11:24 PM   #2
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: Spark plugs
I use Denso W16P-U in my 383 and 440 engines.I also use Accel,but I cannot remember the number on them.The Accel plugs are made by Denso.The W16P-U is equal to a Champion J-11-Y.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 08-25-2007, 12:23 AM   #3
Philip Saran
Chris, thanks for the reply. Guess I should have just emailed you direct
in the first place.
Phil Saran
Parker, Colorado
