Old 09-03-2017, 12:32 PM   #1
rod
Liked 20 Times in 15 Posts
Smile intake port CC ?
what is the relationship between intake runner CC and engine cubic inch?
I assume that projected rpm, cam and compression are also involved.
thanks Rod in AZ
rod is offline   Reply With Quote
Old 09-03-2017, 03:10 PM   #2
SSDiv6
Liked 1,538 Times in 575 Posts
Default Re: intake port CC ?
thanks Rod in AZ
Although a broad question, yes, intake runner size has an influence on the projected performance of the engine.
Old 09-03-2017, 10:29 PM   #3
Ed Wright
Ed Wright's Avatar
This is the Stock & Super Stock section. We have no choice but to use the NHRA spec for our particular engine.
Ed Wright 4156 SS/JA
Old 09-03-2017, 10:52 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Pick the head that has the largest cross sectional (CSA) area for the cubic inch you are running.. CC's can trick you because a long narrow port can have a small CSA and another port with the same CC can be short with a bigger CSA. The long narrow port will usually have high velocity that makes low end TQ & limits RPM, esp if they are small for the Cu in of the engine.
Adger Smith (Former SS)
