Old 08-24-2017, 11:56 AM   #1
201250
201250's Avatar
Default Help from Cobra jet owners/drivers front suspension
I have searched the internet far and wide trying to find out how on the 2012-2014 cars the front tires are moved inbound so not to be flush or stick out past the fender well. My current front suspension consists of Viking double adjustable front springs and struts, UPR caster/camber plates and Baer SST front brakes with Billet Specialties comp 5 wheels with 2.25 back space.
I run a tall front tire and the sidewall sticks out past the fender lip and looks like CRAP. Any help would be greatly appreciated
Terry
FS/H 2012
Terry Crow
2012 FS/H
201250 is offline   Reply With Quote
Old 08-24-2017, 01:10 PM   #2
nhramnl
Liked 358 Times in 83 Posts
Default Re: Help from Cobra jet owners/drivers front suspension
Call Mike at MPR. If anyone in the world has solved the problem, it will be him 810-798-1998.
Old 08-24-2017, 01:27 PM   #3
201250
201250's Avatar
Thanks I will call him.
TC
Terry Crow
2012 FS/H
Old 08-29-2017, 05:44 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
On the website, the # is: 1-810-798-8998
Dave Noll, EF/S ,?/SA 6526
Old 09-01-2017, 05:39 PM   #5
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Hey Terry, tucked in how far? Mine didn't stick out, at the time of this photo the 11 had the same brakes as you with a small spacer for the street wheels to clear them. Those are the rather balloon like 29" fronts too.
On the 13 these are the same 29" tire with same backspace, no spacer needed for these brakes/wheels.
K Danner STK 468
kdanner is offline   Reply With Quote
Old 09-03-2017, 05:36 PM   #6
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
I shortened my front lower control arms by 1.5 inches. The bracket that holds the lower ball joint can be removed by using a cut off wheel to grind out the weld. Then cut the arm off 1.5 inches and place the ball joint assembly back in the channel and weld it back in. You will also have to shorten the tie rod end and the rack end. The picture shows my old drivers lower control arm next to the shortened drivers control arm. I now have 0 degrees camber with the wheels tucked under.
ID:	42058   Click image for larger version
ID:	42059   Click image for larger version
ID:	42061   Click image for larger version
ID:	42062   Click image for larger version
ID:	42064   Click image for larger version
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 05-29-2018, 08:16 AM   #7
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
George, what type of bushings are in these control arms ?
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 05-29-2018, 10:28 AM   #8
George Wright
Jerry,
Its a ball bearing bushing. Calvert Racing has them.
Old 05-29-2018, 10:54 AM   #9
JHeath
JHeath's Avatar
Thanks George !
Jerry Heath
I/S '93 Cobra
Old 05-29-2018, 03:50 PM   #10
bry-war
Liked 2 Times in 2 Posts
Would anyone clarify the difference between a 12 and 13 control arm? I am certain that the bushings had less stiction for 13. Thanks!
Bryce
bry-war is offline   Reply With Quote
