Old 08-03-2017, 10:06 PM   #1
GSlaton
Liked 26 Times in 12 Posts
Default 12 bolt ring and pinion question
Does anyone know of a ratio available between the 5.57 and 5.86? The 5.57 is a 7/39 and the 5.86 is 7/41. A 7/40 would be 5.71. Is there a technical reason that the 7/40 cannot be made?
thanks
Gary
GSlaton is offline   Reply With Quote
Old 08-04-2017, 06:35 PM   #2
SSDiv6
Default Re: 12 bolt ring and pinion question
thanks
Gary
Would not recommended it.
Ring and pinion gears are conjugated by design and matched to each other during the manufacturing process. They are also lapped between each other and the reason why they have different pinion height specs on identical gear set ratios.
Old 08-04-2017, 08:09 PM   #3
Woodfin
Liked 288 Times in 109 Posts
Interesting question, I have never considered how/why certain ratios are built.
Maybe one of our engineers will explain.
Old 08-04-2017, 08:45 PM   #4
SSDiv6
In simple terms, ratios are designed and built for the specific requirement.
The term I used earlier, gear conjugation, is the constant angular velocity profile of the teeth when they mesh, based on a fixed reference direction and defined by a constant angle.
Since the gears are referenced in special tooling at the manufacturer and lapped, the reason why if you swap pinions and gears, you are creating lots of problems for yourself.
Old 08-04-2017, 10:03 PM   #5
Mark Ugrich
Liked 71 Times in 38 Posts
Aren't the actual ratio numbers determined by ring gear size /diameter and pinion location ? I was told that is the reason a Ford 9" has a different selection of ratios vs. a 12 bolt or Dana .
Old 08-04-2017, 10:04 PM   #6
Woodfin
Mr Slaton, please correct me if I misunderstand your question.
I do not think he is asking or suggesting to mix ring and pinion sets.
My take is that he is simply asking why a certain ratio and tooth count is not built. Or to ask another way, why/how is the decision made in ref to available ratios. Is there some engineering reason for the tooth counts and ratios the market has available?
Old 08-04-2017, 11:20 PM   #7
GSlaton
Your right Larry I was not suggesting mixing ring and pinion. I saw an ad in the parts for sale section. One of the items was a 5.71 for a 12 bolt. Someone must have made one at one time but I cannot seem to find the ad as it was sometime ago.
Gary
Old 08-05-2017, 12:04 AM   #8
SSDiv6
Gary
It's called supply and demand.
The largest selection of gears in use for drag racing is in the Pro Stock class and they are made by Gleason, however, they are for the 10" and 11" drop outs they use. Big money too!!!
