Liked 880 Times in 311 Posts
Is this the new Mopar intake awaiting NHRA approval?
Dig the part number!! http://www.ebay.com/itm/Aluminum-Tun...-/152603504474
Adger Smith (Former SS) |
Liked 53 Times in 38 Posts
Yea, they should, been hard to find the cast iron one for sometime. Came factory on RR and Newports
Liked 25 Times in 16 Posts
Adger, please submit one of these for the 440-6 for Stock. I have one, but it has popsicle sticks glued to the floor. With the aluminum top on the right. The wooden looking one probably won't be legal for stock. They had Chrysler part numbers on them and several tops.
Mopar 2 Ya! |
More of the Weiand cross/tunnel ram intake. Paul Rossi ran this on his Sixpack Challenger 40 years ago. It must have terrible distribution with the 6 pack. I can see where fuel ran all over the bottom of the plenum (very shallow) from the center carb.
Mopar 2 Ya! Last edited by James L Miller; 07-24-2017 at 01:28 PM. Reason: Try to load photos again. |
#5 | |
Liked 307 Times in 116 Posts
I don't think Weiand made one for the B engines. That would have been a good intake for the 1962 383/343HP engine. It's a pretty tall intake though.
Mopar 2 Ya! |
I just checked my old Chrysler manual, it was at Keith Black they modded the 440-6 Weiand mani for the 383/343s, if you get a chance, can you measure the width of it or see if it has been milled.
Paul, my intake measures about 8.7" across at the rail (straight across, not on the diagonal along the valley rail). I have a B engine Hogan intake and it measures about 7.4" straight across. The Hogan has raised but has wide but short ports, so whatever heads they fit were extensively modified. The Weiand intake looks unmodified except for the popsicle sticks.
Mopar 2 Ya! |
I'm pretty sure Weiand didn't make a 2/4 top. single dom and 3/2s only for the high block. With the fixes to the intake Chrysler did, the manifold worked quite well. Certainly not to be confused with the 2/4 tunnel ram in first post. Lookout you could be stirring up the wild dogs on this site about alumium Mopar intakes.
I was just jumping on Adger's post about the tunnel ram feeding him some straight lines so he could land the punch line. Bah-dum-dum!
I'll be here all night and don't forget to tip your waitress.
Mopar 2 Ya! |
