Old 07-14-2017, 03:00 AM   #1
jaf2021
Liked 5 Times in 5 Posts
Default Hollow stem valves
Any performance gains by using hollow stem valves?? Pros and cons??
jaf2021 is offline   Reply With Quote
Old 07-14-2017, 11:21 AM   #2
rx dealer
Liked 53 Times in 13 Posts
Default Re: Hollow stem valves
Jaf, I bought a set manley solid valves for my LS3. The hollow stem were 6-8 weeks out and $250 more for a savings of only 9 grams a valve. that might seem little but x 16 valves and that adds up. So the new valves, heads,cam, lifters,rockers along with the factory hollow stem valves all went on a spintron to see where i stand and valve control was good to 9400 RPM. on both solid and hollow stem. point is I don't think it matters. I was worried having heavy valves but the spintron proved me wrong. I did find out that my valve springs were too heavy on the seat. I hope this helps...Luke SS 311
rx dealer is offline   Reply With Quote
Old 07-14-2017, 12:22 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 2,024 Times in 607 Posts
I have not had good luck with Manley valves of late. I have lost 2 engines recently due to exhaust valves dropping the head off. What are you using for exhaust valves? 350 super stock engine. Anyone else having this issue?
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 07-14-2017, 01:13 PM   #4
rx dealer
Mike, this engine is a 396 LS3 COPO Super Stock engine. I use the extreme duty XH-432 exhaust valves from manley. A friend lost 2 engines ( 396 big block stocker ) using another top brand valve. is it the luck of the draw? who knows. fingers crossed...Luke SS 311
Old 07-14-2017, 01:58 PM   #5
Rob Wright
Liked 21 Times in 7 Posts
It matters a lot if you have a cam with "iffy" lift curves. You can easily lose 1,000 RPM of peak limiting speed by changing to solid stem from hollow in some combinations.
For heads popping off valves, I'll bet a hundred they had severe bounce at closing. That's generally what will make things break. Good thing some people test this stuff.
Rob Wright is offline   Reply With Quote
Old 07-14-2017, 03:22 PM   #6
junior barns
Liked 20 Times in 14 Posts
you mean too much seat pressure or not enough???
junior barns is offline   Reply With Quote
Old 07-14-2017, 05:37 PM   #7
rx dealer
I wonder who recommended the spintron test...well worth it.. no guessing or mismatch parts...Thanks Rob!! Luke SS 311
Old 07-14-2017, 05:47 PM   #8
Ed Wright
Ed Wright's Avatar
What did you see on the Spintron that indicated too much seat pressure?
Ed Wright 4156 SS/JA
Old 07-15-2017, 01:55 PM   #9
Rob Wright
It generally just didn't look as smooth with more deflection near the nose and a little bit of drumming at the closing point. 150 lb less spring Force cleaned it all up and made it look beautiful.
High spring force is definitely not your friend all of the time.
Old 07-15-2017, 02:04 PM   #10
Jim Hanig
Liked 99 Times in 49 Posts
How much did you have on the seat?
