Old 06-02-2017, 10:30 PM   #1
rod
Liked 20 Times in 15 Posts
Default carb. jetting?
Holley 4776-600 CFM DP, since the blades are the same size and the venturis are the same size---you should be able the square jet. right?
the only thing I can see,which would be different [SBC-Power Products intake] is that the front manifold runners are shorter than the rear runners.
your thoughts.
Thanks Rod in AZ
rod is offline   Reply With Quote
