Old 05-18-2017, 11:27 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Short Chain For GM OEM Roller Camshaft
Does anyone know where to source a -.005 or - .010 timing chain for a OEM nosed roller camshaft? Getting a Comp Cams cam for a 91 TPI roller block that has been align bored. I know I can order a older type nose on the cam and use a button to limit travel but wanted use the retaining plate system. Thanks.
brian schuetta is offline   Reply With Quote
Old 05-18-2017, 12:05 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 965 Times in 306 Posts
Default Re: Short Chain For GM OEM Roller Camshaft
Cloyes, Rollmaster
Old 05-21-2017, 06:19 AM   #3
richie 2
Liked 200 Times in 91 Posts
comp chains r actually cloyes units. call cloyes direct as they r very helpful and top of the line components...
Old 05-25-2017, 03:39 PM   #4
brian schuetta
I heard back from Rollmaster, they use a larger lower gear compensate, cool.
