Old 05-09-2017, 04:16 PM   #1
Rick.H
Default Lt1 92-97 motor questions.
Changed opti to opti with msd cap and rotor and found out that the dowel pin was only 0.230 into the drive slot, I think they recomend 0.380
Sprocket bolts seems grinding in drive slots, wrong timing set oem roller ?
Oil pump drive dident looks so good,cracked tighten more than 13ft-lbs or can it be any other reasons ?
Can you use a bronze gear on the oil pump drive?
ID:	39506   Click image for larger version
ID:	39507   Click image for larger version
Rick.H is offline   Reply With Quote
