Old 05-08-2017, 10:24 AM   #1
Comp 798
Comp 798's Avatar
Default Question: K&N Air Filter for LT1
Anyone using a K&N Air Filter that attaches directly to the stock LT1 throttle body know the part #? Thanks.....
Sam Tufano
Comp 798 is offline   Reply With Quote
Old 05-08-2017, 02:43 PM   #2
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: Question: K&N Air Filter for LT1
You wouldn't believe what I went through to find this out. Glad to pass it along! K&N Air Filter LT1 59-5020 http://www.jegs.com/i/K-N/599/59-5020/10002/-1
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 05-08-2017, 10:46 PM   #3
Tom Meyer
Liked 351 Times in 120 Posts
Are you running it down track or just in the pits? On my sons 500 hp LS1 street car we lost 6 hp on the wheel dyno with the air filter on. Tom
Tom Meyer 5240 SS Stock ???
Old 05-09-2017, 12:59 AM   #4
Paradigm Shift
Liked 80 Times in 29 Posts
The reason for the loss is attributed to the permeability of the gauze media in question - approximately 80 SCFM per square foot at .5" w.g. In addition, the outlet configuration and resulting profile are poor.
Why are you considering the use of a filter?
Paradigm Shift is offline   Reply With Quote
Old 05-09-2017, 01:18 AM   #5
Darrel Goheen
I run it all the time with filter.
Old 05-09-2017, 07:48 AM   #6
Ed Wright
Ed Wright's Avatar
I'm guessing you don't use the Jessel belt driven front mounted distributor? I used one at dusty tracks, until I went to a Bowtie block and put that thing on. Won't fit now. I have zip tied a damp shop towel over the TB to try to keep dust out of my cylinders. At Noble I often pull it off in the staging lanes, put it back on down on the return road. Every year I swear I'm not going back. LOL
Ed Wright 4156 SS/JA
Old 05-09-2017, 10:16 AM   #7
Darrel Goheen
I don't have a Jessel belt drive as I don't think that would be allowed in Stock. I use a filter to keep non air particles or chunks out of engine.
Nobile is one of the dirtiest pit areas I've encountered. Ennis is right there too.
Old 05-09-2017, 10:45 AM   #8
Ed Wright
Ed Wright's Avatar
Tulsa is also nasty if it is dry, worse if the wind is out of the north. Blows dust from that pasture looking area, used for pit space at points races, all over all of us. Ennis, a couple weeks ago, was not bad.
I put the damp shop towel on, pull it in the staging lanes just before getting in the car, put it back on at fuel check. Spent too much on expensive pistons, rings, and honing, for good ring seal to suck that crap through it. If it was just a bracket car, I would not have that kind of parts in it, would not be as big a deal to me.
Old 05-09-2017, 12:17 PM   #9
HR9121
HR9121's Avatar
I run mine all the the time except heads up runs ofcourse. 😀
James Williamson
W200 J/SA. SS/JA
Old 05-09-2017, 01:55 PM   #10
Mark Faul
Liked 43 Times in 9 Posts
I run mine all the time on my Super Stocker. Had to put a little dent in it and tweak it to fit around the front drive distributor. Haven't noticed a difference with it vs without. But I don't make much HP.
If I tried Ed's towel trick, I'm sure I'd forget and leave it on. Not quite as old, but forgetful! LOL
Mark Faul is offline   Reply With Quote
