Old 05-05-2017, 01:08 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default weather info
can someone give me a run down of what too look for as far as air goes what makes good and bad air, in the past i've just paid attention to temp but we are getting more serious and need to keep a better eye on things. and we are going to test tonight and the track is saying barometer of 29.94 and 72 degrees with 46% humidity i don't have water droplet or grain information but too me these sound like good conditions. any input or explanation would be appreciated.
Thank you
Patrick Ford
pfordamx is offline   Reply With Quote
Old 05-05-2017, 01:36 PM   #2
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default Re: weather info
There's a website called: airdensityonline.com
It will give you the water grains, temp, humidity, barometer, corrected altitude.
Just look at the list of tracks & select what track your at.
Usually updates every hour.
What i've been told is: the less water grains the better you'll run.
One thing to definitely look at if you race in the summer months.
Keep a log book & write down all of the info when you race, also the time of day.
Hope this helps you.
"Pistol" Pete Dutko
Old 05-05-2017, 05:39 PM   #3
pfordamx
That helps a ton thank you.
Old 05-08-2017, 06:11 PM   #4
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Our PerformAIRE weather stations will provide you all the weather information you need along with the correct density calculations as they relate to horsepower in an internal combustion engine.
Give us a call to discuss your needs!
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
