Old 05-04-2017, 08:24 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile return line
building another sb stocker for my son , do I need a return line for this carburetor engine?
Mike Savelle is offline   Reply With Quote
Old 05-04-2017, 08:29 AM   #2
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Default Re: return line
Hi Mike...I used a -8AN return in my fuel system. I don't regret spending a little extra on hose, fittings and the regulator to get the benefits as compared with the dead head style. Very consistent pressure at all times.
Dave Turner
SS/GT #1153
Old 05-04-2017, 11:35 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
Mike,
with several builds/upgrades, each one has smooth, steady pressure with the addition of a return line.
*The ultimate [when rules allow] belt drive pump with bypass regulator
*When rules require an electric pump I like a return style regulator that has a vacuum feature. Even with our radical cams just a few inches of vacuum at low speeds bring the pressure down about 2 - 3 pounds below the wide open [vacuun line removed] setting.
*At light throttle, the engine is less "blubbery" with lower fuel pressure
Larry Woodfin 471W
Old 05-10-2017, 11:48 AM   #4
njk53
Before we reworked our complete fuel system we were dead heading the fuel line to the carburetor. We went with a new Aeromotive fuel pump and regulator. It was recommended by Aeromotive to put in a return line which we did. The system to date has been working well with no fuel delivery related issues.
Nelson Kowal
Stock 345
