Old 04-14-2017, 07:58 AM   #1
Chris1529
Liked 70 Times in 29 Posts
Default Bias vs Radial Slick
I have 28 x 9 M/T Bias slicks on my car right now. If I switch to a 28" Radial, can I expect much finish line RPM difference? Anyone have any finish line RPM info they can share when switching from Bias to Radial on the same size advertised tire on?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 04-14-2017, 08:15 AM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: Bias vs Radial Slick
Chris, what size rim?
J.R. Haddad is offline   Reply With Quote
Old 04-14-2017, 08:20 AM   #3
Chris1529
8"
Chris Bowman
1984 Mustang GT350
Old 04-14-2017, 08:34 AM   #4
J.R. Haddad
Chris, with an 8" rim you're getting reasonable growth with the Bias
tire. You will get next to no growth with the radial tire. That should result
in 3-400 more finish line RPM. J.R.
Old 04-14-2017, 10:12 AM   #5
Rory McNeil
.........Except unless M/T has recently changed this, the 9X28 bias slick is actually less than 27 1/2 inches tall. So the finish line RPM may be fairly close.
NHRA 6390 STK
M/S 85 Mustang
Old 04-14-2017, 11:48 AM   #6
Chris1529
27.3" dia with 86" circumference for the bias, 28"dia with 87.8 circumference for the pro-bracket radial.
Chris Bowman
1984 Mustang GT350
