Old 03-23-2017, 11:27 PM   #1
Bob Lasko
Bob Lasko's Avatar
Liked 185 Times in 54 Posts
Default Hood Scoop Opening
How far in front of the carburetor should the opening of the hood scoop be???
This is for a SS/CS car with a 318 CU Chevy small block with a 750 Book Carb.
Your input would be appreciated.
Thanks,
Bob Lasko
Old 03-24-2017, 12:39 AM   #2
SSDiv6
Liked 1,538 Times in 575 Posts
Default Re: Hood Scoop Opening
Thanks,
Bob Lasko
Bob,
The distance will vary based on the hood scoop design and the constraints of the rule book as regards to size.
One of the most important things is to make sure the carburetor has a pan that provides a good seal against the hood scoop.
Take a look at these article:
http://www.onallcylinders.com/2015/0...op-technology/
If you can find a copy, the old Direct Connection technical manuals had a great chapter on hood scoop design and optimum location.
Old 03-26-2017, 07:51 PM   #3
Bob Lasko
Bob Lasko's Avatar
thanks for your input. the article helps out.
bob
