Old 03-18-2017, 07:14 PM   #1
Everett Vassar
Liked 2 Times in 2 Posts
Default C-11 question
I have (2) 5 gal un opened pails of C11 in my trailer from Oct. .is it OK to use?
Everett Vassar is offline   Reply With Quote
Old 03-18-2017, 07:43 PM   #2
Mike Croley
Default Re: C-11 question
You should be fine if it was stored correctly. Meaning, if the fuel was on a wooden floor or wood planks, and if the daytime inside trailer temps weren't far higher than the night temps, it should be usable. The Renegade crossover fuel, Pro Crate 108, has a shelf life of 2 years when stored correctly.
If you have any doubts, 2 new pails of fuel are far cheaper than a piston or two.
Mike Croley is offline   Reply With Quote
Old 03-18-2017, 08:34 PM   #3
Everett Vassar
I felt pretty good till I read your last sentence. .so your saying if the fuel is bad it will go lean? It's been sitting in the trailer on a wooden floor all winter had one freeze but hasn't been past mid 80,s here in the DFW cluster F
Old 03-18-2017, 08:41 PM   #4
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Should be OK to run. As far as passing check might be another matter.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-18-2017, 08:49 PM   #5
Bruce Noland
Liked 444 Times in 145 Posts
You should be fine. Take both cans over to fuel check if you're going to a sanctioned event and they can tell you if they are legal. I've never heard of C11 burning pistons before.
Bruce Noland 1788 STK
Old 03-18-2017, 11:06 PM   #6
rboyle
rboyle's Avatar
Liked 602 Times in 165 Posts
Hi Bruce, when you ran the small blocks was c11 faster than c12 and was there a difference in consistency for you? You can PM me if thats better.
Thanks
Old 03-18-2017, 11:48 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: C-11 question
Thanks
C11 is faster in low compression motors. Most low compression racers use C11 over C12. Jim
Old 03-19-2017, 11:59 AM   #8
Everett Vassar
Thanks
I am also interested
Old 03-19-2017, 12:42 PM   #9
Bruce Noland
I like C11 for a lot of reasons. For me it has proven to be faster without suffering any reliability issues. I am the reason my cars have suffered reliability issues over the last 20 years or so. It all comes down to tweaking your combination. Obviously, you have to double check your metering/jetting and timing after every mechanical change you make. It's what makes the sport fun.
Old 03-19-2017, 02:08 PM   #10
James L Miller
Liked 25 Times in 16 Posts
My thought is the light ends of gasoline that evaporate quicker (butane, etc.) have the higher octane ratings than the heavier molecules. Maybe the problem becomes detonation instead of going lean?
https://en.wikipedia.org/wiki/Octane_rating
Mopar 2 Ya!
