Old 08-11-2007, 09:13 AM   #1
Robert Pare Racing
Robert Pare Racing's Avatar
Liked 2 Times in 1 Post
Default Fuel Injected sample valve
does anyone use a Jegs style fuel sample valve?. I am concerned about the higher fuel pressure blowing out the o-rings. Thanks.
RPare@CoppermineApplicators.com
Rapare-Racing.com
Robert Pare Racing is offline   Reply With Quote
Old 08-11-2007, 03:28 PM   #2
Tim Kish
Liked 11 Times in 4 Posts
Default Re: Fuel Injected sample valve
I'm running the similar style valve from Clark Holroyd at 45 psi with no issues other than fule comes out REAL FAST when your taking a sample at higher pressure.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 08-13-2007, 01:20 PM   #3
Oclk Dlux
Smile Re: Fuel Injected sample valve
I'm running the Aeromotive #15631 sample valve. I like it better than the Jegs because it has a 1/8 fitting on the side for a pressure gauge. I've ran 75# with no problems. It's only "For A Few Dollars More" at Jegs.
Rich Hedden
6011 BF/S
Oclk Dlux is offline   Reply With Quote
Old 08-13-2007, 06:13 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Bob, I've used a couple of the Jegs valves on EFI cars with no problems. .... I agree with Oclk,the Aeromotive is a nicer piece for only a few more bucks, and it'semi idiot proof . ,,, Tom
Old 08-19-2007, 12:52 PM   #5
davyjones
... the jegs valve , jerry bickel valve , ART valves are all manufactured by Clark . I have never had an Aeromotive valve apart so I cant' say were comparing apples to apples here , but the way the top half swivels it would be logical that It also has o-rings in it . When I designed and prototyped the "CLARK" valve I put alot more pressure on it in testing than you will ever see from a gasoline fuel injection setup. I think this new aero valve is bulky and my main dislike is having an alum part that threads into an aluminum part with a pipe thread . Thats why the CLARK valve has a stainless fitting .
davyjones is offline   Reply With Quote
