Old 02-19-2017, 11:05 PM   #1
rod
Liked 20 Times in 15 Posts
Default slick size info
measured section width for Phoenix bias real drag slick, 9 x 28.5. all measurements taken at 15 lbs.
height [these are an approximation between the corner and the high point in the center of the tread]
it should be noted that as the rim gets wider the section width moves closer to the rim.
rim SW tread height
7 11 1/8 9 28.5
8 11 1/2 9 28.5
8.5 11 1/2 9 28.5-
9 11 3/4 9- 28 3/8
10 12 1/2 9- 28 1/4
Rod in AZ
rod is offline   Reply With Quote
Old 02-20-2017, 08:03 AM   #2
axman
Default Re: slick size info
That was the info I was looking for. Web. said they were 12.5 on a 8"rim.
axman is offline   Reply With Quote
