Old 02-18-2017, 12:29 PM   #1
S/ST 3040
S/ST 3040's Avatar
Default Thermo-quad Tips
I am attempting to build my own Thermo-quad for 72-73 340. I don't want anything on it I don't need
but, leave or modify everything I do. Is anybody willing to share any tips on successful modifications?
Fuel pressure?
Is the vacuum diaphragm on right rear necessary to regulating air door?
Is converting to Holley jets and removing the metering rods from primary circuit the best?
Is removing the choke S/S legal?
Is a -6 inlet adequate for fuel delivery at say 530 HP?
I've read about 40-50 HP differences in modified Thermo-quads so, there must be some things that work better than others.
Thanks
S/ST 3040 is offline   Reply With Quote
Old 02-18-2017, 01:18 PM   #2
Woodfin
Liked 281 Times in 108 Posts
Default Re: Thermo-quad Tips
You might find some suggestion on this site;
http://racingfuelsystems.myfunforum....490f1b3f04bd47
Woodfin is online now   Reply With Quote
Old 02-18-2017, 03:16 PM   #3
dusterfinland
Liked 4 Times in 3 Posts
I run 74 duster in ss/ja 360cid here in finland,.I have problem all the time with accelerate pump seal ring i have use blue and orange rubber,.When it gets race fuel it goes fat and after that wont work at all,.same times cant get engine runnin before I take the thermoguad at pieces and change the rubber,.here in europe we run unleaded racing vp fuel could this be the problem..thanks
dusterfinland is offline   Reply With Quote
Old 02-18-2017, 03:39 PM   #4
treessavoy
Liked 4 Times in 4 Posts
Contact Jim Wahl, he's very good with these carbs. He's a member here.
Jim Rountree
Old 02-18-2017, 03:59 PM   #5
Liked 10,721 Times in 2,232 Posts
Van Lant
Old 03-04-2017, 07:09 PM   #6
HIGHOCTAIN2000
Anyone have a sorce for thermoquad secondary jets
HIGHOCTAIN2000 is offline   Reply With Quote
Old 03-04-2017, 10:24 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Fuel pressure?
Thanks
Sent you a message
Jim
Old 03-04-2017, 10:28 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You can buy the good accelerator pump seals from Ninja Fuel Systems on eBay . Compatible with ethanol laced fuel .
Old 03-04-2017, 11:39 PM   #9
GTX JOHN
Liked 2,486 Times in 697 Posts
Holley Jets make it a lot easier to tune because readily available.
No metering rods make it a lot quicker to disassemble and assemble
as they are a pain.
Choke must remain in Carb.
-6 works fine...Big float bowl capacity
Diaphragm not vital but helpful in controlling Air Door.
My opinions.......Your results may vary.
John Irving
741 Stock
741 Super Stock
Old 03-05-2017, 06:36 AM   #10
HIGHOCTAIN2000
Do you have holly jets in the secondarys, or only in the primarys
