Old 02-11-2017, 09:21 PM   #1
M Brand 505B
Liked 31 Times in 10 Posts
Default Rochester 2gc - Chevy 400
Anyone have a 1970-75 Chevrolet parts book that confirms which part numbers were on the Chevy 400 2gc? Trying to confirm which CFM carbs were available. On the blue print specs it only shows a 1.25 carb which I believe is the 381 cfm.
Thanks,
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 02-11-2017, 09:45 PM   #2
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: Rochester 2gc - Chevy 400
Look out for an OEM carb, then measure the ventures. Some of these are the 1.375" venturi, and the alternate carbs shown on the blueprint specs on your Tech Bulletin specify the smaller venturi,even though the car originally came with the larger one. Some replacement parts differed from the OEM.
Old 02-11-2017, 11:54 PM   #3
MAURICE BLENDHEIM
Liked 286 Times in 88 Posts
Default Re: Rochester 2gc - Chevy 400
Michael… 1970: 7040117, 7040118, 7040119, 7040120. 1971: 7041118, 7041137. 1972: 7042118, 7042838. 1973: 7043118, 7043119. 1974: 7044118. 1975: (4 barrel only). 1.25=381cfm, 1.312=423cfm, 1.375=435cfm. The are all referred to as "Large Base" starting in 1970. I hope this helps…Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 02-12-2017, 12:33 AM   #4
NORMAN BARNARD
Liked 2 Times in 2 Posts
Maurice, what is the test pressure being used to arrive at those flow numbers?
NORMAN BARNARD is offline   Reply With Quote
Old 02-12-2017, 01:48 AM   #5
FED 387
Liked 336 Times in 183 Posts
3.0-fed387
Old 02-12-2017, 11:33 AM   #6
V M Kauffman
4 bbl 3.0
2bbl. 1.5
1 bbl. 1.0
All are SAE Specs
V M Kauffman is offline   Reply With Quote
Old 02-12-2017, 11:38 AM   #7
Run to Rund
Liked 56 Times in 29 Posts
Under vacuum, 3" was used for 2 bbl since originally at WOT that was about the vacuum achieved; 1.5" was used for 4 bbl carbs. The conversion factor is discussed in Doug Roe's book, and for example the 1-3/16" venturi carbs would give 247 cfm on the 4 barrel scale, 1-5/16 about 299, and the 1.25" iirc around 280.
Old 02-13-2017, 05:40 PM   #8
M Brand 505B
Thanks for the help so far. The particular carb number that is listed for the 74' 400 is 7044118. If anyone has this carb laying around can you please measure the venturi size for me?
Michael Brand II
505B - F/SA
Old 02-18-2017, 10:35 AM   #9
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
This might be of interest .......
http://www.ebay.com/itm/GM-Chevy-Che...NX~WfV&vxp=mtr
Dave Noll, EF/S ,?/SA 6526
