Old 01-20-2017, 04:29 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Opinion on what converter will act like with rear gear chan
Installed a RPM datalogger and have noticed my converter is about 200 rpm's to tight. I currently have a 4.30 rear gear and going to change to a 4.88. Will the converter become tighter due to not working so hard ( lack of a better term) with the 4.88? I have a converter that is about 400 rpm's looser then the one in the car now and the motor is out and can change quickly. Thanks in advance Jeff
Old 01-20-2017, 06:35 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Opinion on what converter will act like with rear gear c
yes more gear will make the convertor flash at a lower rpm.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-20-2017, 07:34 PM   #3
Jeff Stout
Thank you. I'll put the other converter in
Old 01-21-2017, 01:34 AM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Just a suggestion , make one change at a time .
