Old 01-20-2017, 09:43 AM   #1
Joe Grippo
Liked 41 Times in 4 Posts
Default Early Mustang 1" Upper A-Arm drop
Has anyone done the 1" Upper A-Arm drop modification (Shelby Drop) on their 64-70 Mustangs? While primarily a road racing thing, there are supposed to be some benefits in lessening the positive camber gain on the launch and wheelstand. I have spoken to a few guys and they seem to be split on whether there is a benefit to doing it.. I am trying to keep the wheels straighter on launch, as now the tops of the tires lean in. How did this modification effect your alignment?
Any thoughts?
Joe Grippo is offline   Reply With Quote
Old 01-20-2017, 07:35 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Default Re: Early Mustang 1" Upper A-Arm drop
I am planning to do it on my Shelby stocker.
I don't think it would hurt anything.
http://opentrackerracing.com/technical/
Mike Gray is online now   Reply With Quote
Old 01-20-2017, 09:34 PM   #3
V M Kauffman
When Joe Spinelli was restoring the Super Stock Maverick I had a chance to see the body. It had that mod done to it. This mod is to drop it 1 inch and move it back 5/8". There is a diagram in the old Ford Boss 302 chassis book. Another Ford trick is to heat the steering arm on the spindle bend the arm down right at spindle about a inch the heat the portion that tie rod attaches to and bend that mounting hole back up about a inch the helps bump steer. It's a lot of work but it's worth it.
Any thoughts?
V M Kauffman is offline   Reply With Quote
Old 01-20-2017, 09:41 PM   #4
Ryan Horensky
Liked 109 Times in 18 Posts
Any thoughts?
Hi Joe,
Give my dad a call. He can give you information on this.
570-788-4482 (Home)
570-956-8665 (Cell)
Ryan Horensky is offline   Reply With Quote
Old 01-20-2017, 09:44 PM   #5
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
I would think drilling holes and changing mounting points may be a no-no. I know tall ball joints and off set shafts are used. but I would check with your div. tech director about changing the mount location?
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-21-2017, 01:43 PM   #6
Joe Grippo
Thanks for the replies.
Ryan, I will definitely call your Dad about this...Probably early next week.
Mark, I should have mentioned this is a bracket car.
Joe
Old 01-21-2017, 04:36 PM   #7
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
If you have no travel limiters moving the upper down one inch will do wonders but the real trick as mentioned above, is to move the upper control arm back. Doing so will add more positive caster and allow the car to "track" better going down the track. when you get it right you can put it on the bumper, land and continue on without ever "fighting" the steering wheel
see my build below in the build section...wait I don't have those pics up yet was supposed to be top secret..lol
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
