Old 01-18-2017, 08:02 PM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Help I.D some old napa engine parts?
I have some NOS parts from off the back shelf at a old Napa auto parts store that I'm having a hard time identifying, Anyone have a old catalog laying around?
The first is a wrist pin part #223-1669.
The second is a pushrod with a possible part # of 211-1282. This one may not be right as I found a handwritten tag near it.
Thanks guy's.
2009 V/SA Record Holder
Old 01-20-2017, 12:10 PM   #2
Roberte
Liked 14 Times in 8 Posts
Default Re: Help I.D some old napa engine parts?
A 211 prefix should be a valve part#.
Don't know @ the pin, but keep in mind
those part #'s are the same as Dana and
Perfect Circle numbers.
bob
Roberte is offline   Reply With Quote
Old 01-24-2017, 03:03 PM   #3
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
NAPA guy here with a 1997 book...
I'm looking though all of the common engine sizes of mainstream American makers but not finding either of these numbers yet. What I CAN tell you with certainty, like Roberte said, is that the 211-1282 is NOT a pushrod, it should be a valve for a cylinder head. Pushrods can be measured for length and diameter, and head type on each end, and then matched up against a chart to tell what they might fit.
I can also tell you with some certainty that the piston pin number you have is for something pretty ancient, like out of the 1940's or 50's judging from the relatively low number of the last four digits.
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
