Old 01-11-2017, 06:50 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default I'm Curious.
What size carbs came on a '56 chevy panel wagon ???
The engine that had (2) 4 barrel's on it.
Thanks
"Pistol" Pete Dutko
Old 01-11-2017, 07:11 PM   #2
Hacksaw
Liked 310 Times in 174 Posts
Default Re: I'm Curious.
They actually offered an engine combo like that in a panel wagon?
Old 01-11-2017, 07:18 PM   #3
Pistol Pete
Yes. The Yoo Hoo Too 56 Wagon ran that combo back in the 60's...
Wayne Jesel drove it.
"Pistol" Pete Dutko
Old 01-11-2017, 08:15 PM   #4
Randall Klein
Liked 316 Times in 67 Posts
My 56 runs 2 WCFB Carters @ 350 CFM ea
Single 4 is 375 I believe
Old 01-11-2017, 08:51 PM   #5
Pistol Pete
Thank you Randall.
"Pistol" Pete Dutko
Old 01-11-2017, 10:05 PM   #6
Ed Wright
Ed Wright's Avatar
Yep! I had one in the late '60s. My first race-only car. Lots of screws to change Jets. LOL
Ed Wright 4156 SS/JA
Old 01-12-2017, 12:10 PM   #7
Randall Klein
Say, Ed, since you go waaay back, I wondered if you tried or had an opinion on:
At Topeka, when Grumpy Jenkins was involved with Pro Stk Trucks, he took an interest in the Nomad, and eventually built the tunnel ram we use; a few years later, again at Topeka, he came by our pits while my late partner, Ron was resetting the float levels....he grabbed a float and took a marker and said why don't you cut these down so bowl holds more.....as he got on his scooter, he said..."might work, might not"
Never tried it, did you
Kinda funny the way he said it
Old 01-12-2017, 01:04 PM   #8
James Perrone
Liked 1,829 Times in 427 Posts
Wow you better listen...lol
james perrone 1290 STK
Old 01-12-2017, 06:06 PM   #9
Ed Wright
Ed Wright's Avatar
Red Anderson told me to not do that. Float bowl capacity is an issue with those. The power your making now, that would be a bigger issue for you than it was for me.
I used bigger needle & seats from Parker Brothers (local company, they are retired now) They did not use tapered needles, but a flat neoprene disk that kinda floated on the end of the needle. A ridge around the hole in the seats. They held high pressures better than conventional needles & seats. They made me some .150" seats, I used 12 psi, and put secondary floats in the front as well. They had the recess in the bottoms to clear the secondary flapper shafts. A little more volume. Red tore me down for Records three times, always made me pull the tops off both carbs. Never mentioned the floats. I didn't either. -
Carroll Caudle worked with Edelbrock, and they always sent him the newest thing for his car. He was very fast at the time they sent him the new "mini ram", like some Pro Stock
cars were running. You could not buy one at the time. He didn't have time to change his car around, and go through all the testing. He gave it to me, I had a local shop cut the flanges down flush, and welded on plates to bolt my WCFBs to. No hood clearance if I just used bolt-on adaptors. Thankfully they were small enough at the flange to match them to my heads. As you remember, we could not touch the heads at that time.
Forgot to add, we did not have the fuel pumps & adjustable regulators we have now.
I used 2 Carter pumps, in series, to get more fuel pressure. I turned one off, except at WOt. Had a toggle switch on the dash for one pump, supposed to be turned on when raced up to leave. Until I forgot to turn it on, and lost a round. Put a push button (universal starter button) under the accelerator pedal to turn that pump on when WOT only. It tended to flood a little at idle otherwise.
