Old 01-08-2017, 10:47 PM   #1
Kegracing
Default which remote oil filter
Picked up a Dart Iron Eagle SBC block for a bracket motor. Going to put it in my 67 Firebird to bracket race for a while...
This block requires a remote filter - no stock filter pad. What is the best way to go here? I don't mind spending a little more for the right thing, but don't want to just waste money either.
Suggestions for best mounting point on a 1st gen. F body?
thanks,
Ken
Kegracing is offline   Reply With Quote
Old 01-08-2017, 11:41 PM   #2
Liked 1,831 Times in 415 Posts
Default Re: which remote oil filter
Canton makes a good one, I prefer the 13/16" thread version that uses a Chevrolet filter, and try to mount them so that I can use a PF932 2 quart filter. I use -12 braided hose, and full flow fittings.
Old 01-10-2017, 10:28 PM   #3
Kegracing
Thank you sir!
That Canton piece looks nice.
Ken
Old 01-10-2017, 10:47 PM   #4
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
CV Products makes a great remote oil filter mount. CV746 is what you need.
Old 01-11-2017, 05:21 PM   #5
Sam Ehret
Sam Ehret's Avatar
I use a Moroso 23766 remote Adapter with -12 lines in and out. I mounted it on the radiator bracket in front. It uses an HP6 frame filter that holds almost two quarts. Mine is a dry sump application.
Sam Ehret is offline   Reply With Quote
