How do I know if I am running out of suspension travel?? I have the Koni Spa1's in front of my 69 Camaro with Moroso 214 rate trick spring uncut, is this a problem that the springs arent trimmed?
Measure from the spindle to the bottom of the wheel opening. Then jack the front up until just before the tires leave the ground. The difference is your travel. Optimally you'd have 6" or more travel on a first gen Camaro.
