11-23-2016, 12:19 PM | #1 |
WTB Turbo Action shifter gate
anyone got a forward pattern gate for a Turbo Action shifter , some how i ended up with two wrong ones .
11-23-2016, 01:43 PM | #2 |
Liked 2,750 Times in 862 Posts
Re: WTB Turbo Action shifter gate
For Mopar yes....if that helps.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock |
11-23-2016, 07:55 PM | #3 |
Liked 7 Times in 5 Posts
any one know if a mopar forward pattern work on a GM shifter ?
11-27-2016, 08:04 PM | #4 |
If you have a reverse pattern gate for a GM shifter I will trade for a forward pattern. Mike, I went to Paul's site, the gate length between park and reverse is 1 inch on gm gate and a half inch on Chrysler gate. The forward pattern gate I have is for a gm. You may want to go to the turbo action site and see what gate you need for your shifter to function properly. I need a 70073b so my shifter moves to the right on 1-2 shift.
Last edited by Dave Crysler; 11-28-2016 at 08:00 PM. Reason: answer a question and state my item for trade. |
11-29-2016, 04:56 PM | #5 | |
Kevin |
12-01-2016, 01:33 PM | #6 |
Dave Crysler all my reverse gates move the shifter to the right . I sent you a PM
12-01-2016, 05:20 PM | #7 |
Liked 49 Times in 34 Posts
12-01-2016, 08:20 PM | #8 |
Here's the thing Mike, I'm poor, I was hoping to trade for a gate I could use if I am ever even able to race again. The measurements I posted tell me that the shifter may not work properly if gates from different models of shifters are swapped. It doesn't really matter because the person that made the inquiry has not even responded.
12-02-2016, 08:46 AM | #9 |
Dave I am the person that inquired I sometime use my work pc. how wide is the stop between park and reverse , 3/4 ,1/2 or 1 "
12-02-2016, 04:08 PM | #10 |
1 inch
