Old 11-15-2016, 10:31 PM   #1
Jeff Stout
Liked 704 Times in 281 Posts
Default Which way to go with cam adjustments in altitude?
SBC with a Super Stock solid roller. Runs great in 2500 adjusted air and satisfied. Now going to 6300 ft of air and I'm asking what would you do with cam timing ( Jesel Belt), Valve lash. Cam is 1 degree advanced and both IN and EX have .026 lash. Would you Advance cam, Tighten lash, loosen lash? Trying to go the right direction with limited testing at track because of time at event. Thank you Jeff
PS This is just about cam timing as I have a converter for altitude that will let motor leave at 6100 and not changing gears
Old 11-16-2016, 06:43 AM   #2
Lee Valentine
Liked 319 Times in 68 Posts
Default Re: Which way to go with cam adjustments in altitude?
Loosen intake lash .010-.015
Lee Valentine 1661 STK
