Old 11-03-2016, 06:22 PM   #1
sandi blair
Default gearing race car
Question:
If you had a 3815 # car w/396/375 peak hp @ 6800 thru 7200 RPM
rear gear 12 bolt
1st gear (tran) th 400
2nd gear tran th 400
what would you want and why?
thanks sb
sandi blair is offline   Reply With Quote
Old 11-03-2016, 08:56 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: gearing race car
Going to need rear tire size ( roll out), and probably torque converter stall speed. I`m sure somebody running that Top Stock combo could help put you in the ball park, without all the numbers, but the data would help
Best wishes
Mike A114
P/SA
Old 11-04-2016, 02:50 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Just to tie things together here, he posted this info in another thread.
"30 x 9 x 15 -94 rol out 6000 stal"
EDIT: Sandi: Use the Post Reply button rather than the New Thread one when continuing an existing topic.
Dale
Dale Shearon
68 Mustang 6394
Old 11-04-2016, 06:51 PM   #4
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
a typical A/SA combo would use a 4.88 or a 5.00 if you can find a set.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
