Old 10-31-2016, 12:14 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default Best bracket carb builder and 4150 or 4500
Looking for carb recommendations for a indy headed 433 inch amc bracket car 10.5 to 1 solid lifter cam .608 lift 255 and 260 @ .050 turbo 400 with 8 inch 5k converter and transbreak, 4.10 gears and 28inch tires on gas. i've been looking at prosystems, apd, blp although i'm open to any advice this will be a no-e car but where i race they do allow the use of a 2-step and transbrake.although it will be footbraked raced occasionally.
pfordamx is offline   Reply With Quote
Old 10-31-2016, 02:20 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Best bracket carb builder and 4150 or 4500
Everyone will recommend the carb builder they use and mine is Pro Systems. Been using and selling Patrick's carbs...4150, dominator and SV-1 for both gas and alcohol for the past 15 years. Everyone has been a bolt it on and forget it experience. I've also done back to back comparison comparing my Pro Systems 1250 Dominator to an APD 1250 Dominator and if I didn't tell you I swapped carbs you wouldn't know by looking at the time slip unlike the APD 4150, 1000HP I got earlier this year that will not rev, burnout or launch cleanly.
Old 10-31-2016, 03:45 PM   #3
pfordamx
PRO-SYSTEMS is definitely a top pick i have a good friend and engine builder in kansas city who is a dealer for them and can get me a carb built at a decent discount. I've seen alot of apds on dragsters and almost no one local here runs prosystems so i thought i'd ask. I guess feel out a form and let mr Patrick James Decide which carb is best for my combo would be the easy way to do that.
Old 11-01-2016, 08:13 AM   #4
cad
cad's Avatar
Liked 93 Times in 52 Posts
Luke Siebert @ Siebert Performance in Topeka. Wouldnt hurt to give a call. Former Stinnett staffer.
My pit partner runs Pro Systems carbs on all 3 of his combos.
Old 11-01-2016, 03:29 PM   #5
pfordamx
On your recommendation i contacted Luke and he recommended one of there 950hp based carbs and had a very reasonable price. this is one of those points when i wish i could buy both and keep the better one.
