10-11-2016, 03:24 PM | #1 |
Liked 9 Times in 4 Posts
St Jude benefit engine raffle
The engine is done that we have built to raffle off for St Jude Childrens Hospital. I'll tell you about the engine, and all parts are brand new:
Dart SHP block Molnar 3.875 stroke 4340 steel crank Molnar 6" H-beam rods with ARP 2000 bolts, Total Seal ringset Diamond 4.155 bore pistons +11 cc dome ACL H series main & rod brgs B&B steel oil pan and pickup Melling HV oil pump ATI balancer Melling oil pump drive Erson custom roller camshaft Erson/Morel roller lifters with bushing Profiler CNC ported 235cc cyl heads ( 23 degree ) Manley severe duty vaves Manley Nextec valve springs Jesel Pro Series shaft rockers 3/8 pushrods Cometic head gaskets Fel Pro intake and oil pan gaskets CV Products belt drive ARP head bolts Edelbrock Super Victor II intake MSD billet distributor ( black ) MSD plug wires Moroso sheet metal valve covers Custom Bill Pink 950 Holley carb Meziere water pump House of Payne Hi-Torque Mini Starter Meziere billet flexplate This engine will come with two 5 gallon pails of VP racing fuel, a MSD 7AL2 box, a $500 gift certificate towards a custom torque converter from Ultimate Converters, two Kowalsky Racing hoodies, and probably a few more items. The engine made 728 HP on our dyno and 614 ft lbs of torque. This is a good, dependable bracket engine. It has 14.5 to 1 compression ( IT IS NOT A STREET ENGINE ) We will sell 200 tickets for $100. each. You do not have to be present to win and you are responsible for picking the engine up. Proceeds go to St Jude Childrens Hopsital. Thanks so much to each and every business that donated to this awesome engine. If you need any tickets, come by or call us (434) 821-6107 or 6109 or look on our facebook page Kowalsky Racing Engines |
