Old 09-23-2016, 01:53 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default Torque Converter who do you use
I'm pretty much inbetween Coan, ATI, and Ultimate open to suggestions of other companies. i'm sure i won't any have isssue with any of those 3 companies just wanted some advice from guys who test alot of converters and if it makes a difference this is going in 3000lb 550hp bracket car that will see both footbrake and transbrake racing i know that means the converter probably won't be perfect for either. but who would you use and the trans is a turbo 400.
Thanks
Patrick
pfordamx is offline   Reply With Quote
