Old 09-21-2016, 10:11 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Metric 200 Auto 1-2 shift
Who manufactures/supplies the components required to convert a metric 200 to auto 1-2 shift and how does this work?
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 09-21-2016, 04:14 PM   #2
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
Default Re: Metric 200 Auto 1-2 shift
My 200 is shifted hydraulically with a plunger that can be adjusted outside of the pan.
If you want a true e-shift, Turbo Action makes a couple things that will help you get there. The controller https://www.summitracing.com/parts/tac-70600 and the valve body https://www.summitracing.com/parts/tac-27255es
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 09-21-2016, 04:47 PM   #3
John Nechiporchik
Jon,Thanks for the response.
I am aware of the Turbo Action E-shift deal. I am just trying to look at all the options for achieving an accurate 1-2 shift in my stocker. My data logger indicates I'm doing a pretty bad job of hitting the 1-2 with any degree of consistency. The 2-3 shift is not a problem.
Can you tell me who did your trans and are you satisfied with the system you have?
Once I get some more info, I'll decide which way to go. PM me if you like.
Thanks for your help.
John
Old 09-21-2016, 08:43 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I drove my LT-1 Firebird shifting it myself and with E-Shift after I sold the car and had the opportunity to drive it again two weekends in a row. Shifting 1-2 manually was always a bit of a challenge since the wheel stand could distract me. I highly recommend going to E-Shift. I would not even consider the auto 1-2 myself.....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 09-22-2016, 07:10 AM   #5
Jon Sarrett
John,
As I understand it, Billy Lynn originally built my transmission. I honestly do not use the auto 1-2, I just click it through.
I'm curious why you wouldn't even consider it Rich?
Jon Sarrett
Stock 3779
Old 09-22-2016, 11:39 AM   #6
Rich Biebel
Without E-Shift my attention is distracted to shifting either once or twice...
With it I can concentrate on the race as it develops.....and to me that is a plus.
If it's legal and it is why not use it...
My Firebird could occasionally do a very high wheelie and on at least one run I shifted way early just from that distraction.....
Shifting the 2-3 was pretty easy but to me making it automatic is good....
I had a shifter that needed a gate plate change and that made it like driving a 4 speed......
I had 3 moves to make to shift twice.....LOL
If I wanted to make racing more about just driving, I'd get a clutch pedal.....LOL
Rich Biebel
S/C 1479
Stock 147R
Old 09-24-2016, 11:24 AM   #7
RichScaz
RichScaz's Avatar
Contact Scott McClay. 661-822-8209.
RichScaz is offline   Reply With Quote
Old 09-24-2016, 11:43 AM   #8
Rod Greene
Liked 242 Times in 81 Posts
Geez what would you guys do if you had a 3rd pedal in the car?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
