Liked 239 Times in 90 Posts
If you were building a 66 chevy ll stocker, would you do just a 6 point roll bar or go ahead and do a 8-10 point cage. Would chromoly save enough weight to offset the expense?
Liked 237 Times in 126 Posts
I put a 10 point ms cage in my 12 second Mustang when I built it just because it allowed me to upgrade the car to a bigger engine package and more speed without ever having to retrofit a cage upgrade. Think about tearing the interior of that stocker apart in a few years. It's not pretty.
Dale
Liked 1,836 Times in 417 Posts
Go 10 point 1-5/8" chrome moly. It makes a nice rock solid stiff car, that you can count on.
Alan Roehrich 212A G/S |
go with full moly cage imo. remember on the chevy everything from the firewall forward just bolts on the car. they have structural rigidity of a marshmallow.
Liked 308 Times in 103 Posts
#6 | |
1.625" Chrome Moly is .083" wall is 1.367 # per foot The weigh savings comes from the fact that you are using a thinner wall material. However in this case the Chrome Moly cage will weigh 29.1% less than Mild Steel. Tom Last edited by PROSTOCKTOM; 08-30-2016 at 10:07 AM. |
Liked 883 Times in 237 Posts
I usually use the 33% figure as a rule of thumb, since most cars done in the last 20 years have .134"wall ERW tube instead of .120 DOM
Average chrome moly roll cage weighs around the same as a .134" wall mild steel roll bar. The added safety from a cage in a car like a shoebox Nova is worth the price and even a few pounds. It's not just how fast you are going any more, you have to consider the 150+mph bullet on 9" tires in the other lane .
Liked 1,436 Times in 299 Posts
Our Nova really benefited from a cage compared to when it had a moly bar in it. They are not the strongest cars. I believe there is a rule change in stock that might allow you to extend the bar past the firewall now. Worth checking it out.
James Schaechter 3163 STK |
#9 | |
Liked 101 Times in 52 Posts
